Power Steering woes M1123
Thunderbirds
503
Northern Black Hills South Dakota
Hey all,
We've been having some dreaded power steering woes, slowly building up to PS failure yesterday and some maintenance not helping thus far.
Hardware:
1999 M1123, single pump/reservoir, serpentine belt.
Dex III fluid level perfect at all times, fresh fluid (6 months).
Cooling fan came on when temperature was reached, and disengaged after, no problems.
Symptoms:
Some slight hissing when revving between 1,000 to 1,500 rpm in the past few months. No other issues.
A week ago, PS was weak at idle, needing some more revs to feel solid at a stand still. Was a little stunned.
Still a solid driver. Yesterday, while pulling into a fast food joint suddenly PS failure unless I revved to 2,000rpm.
Thankfully a 12 mile straight shot from that place via country road doing 55mph, no issues since we were constantly at higher rpm.
Checked everything visually and found a very poor looking return line at the pump/reservoir.
Maintenance done in the past days:
Replaced low pressure hose, replaced Cadillac valve with a know working one with bleed screw at valve (may have been a mistake). Filled reservoir, manually filled hoses with Dex III before connecting them to the Cadillac valve, manually filled clutch hose
Bleed according to TM, up on jacks, engine off, at least 40 - 50 times left, wait 4 seconds, turn right to end wait 4 seconds.
Left in garage overnight, repeated bleeding again this morning.
Nothing really changed, except when I step on brakes, steering becomes harder, when I hit the end (left or right the fan starts spinning up) but still no PS unless I revv to 1,500.
Oh, and now I don't have a temperature indication on the gauge cluster, other gauges work fine.
What have I done, where should I start looking? I do not have any pressure gauges I could use or know how to anyway. o_O Thought about to drive it for some miles, but with the Sturgis motorcycle rally going on this week, I'd rather not endanger the general population.
Thanks for taking time to read and shoot any opinion or question.
Thunderbirds
503
Hey all,
Hardware:
Symptoms:
UPDATE:
at least fixed the temperature indication. I inadvertently pulled the lead from the temp sending unit right next to the low pressure hose near the back of the pump.
Also, now noticing a low level chirp when at idle, never hear that before. Definitely pulley, belt related, but sounds like mechanical chirp not from the belt itself...
Thunderbirds
503
Bled the system one more time this morning, did not help.
I have noticed there is just not enough boost/power to go around for brakes AND steering at idle. It gets better at higher rpm.
Now I am trying to figure out is it more likely some o-rings in the power steering pump or hoses, the pump itself, or even hydro-booster getting weaker?
Any opinions are welcome. Are there specific troubleshooting steps not in the TMs I could perform to narrow it down? I don't want to shotgun parts as that almost always is a waste of time and resources.
Thunderbirds
503
So, at this point I have replaced my power steering pump, and the three EDIT: four low pressure hoses, as well as 2 of the 5 O-rings on the high pressure side.
I have bled the system over 3 days, mornings and evenings 40-50 turns for a total of 6 or 7 sets, hold for 5 seconds at each stop. Kept fluid level at proper amount.
It worked great after that, but developed a whine after 40 miles then the new pump went out. Completely dead to the point where is no steering AND no brakes present... Trying to find out what happened.
Can anyone confirm that the low pressure hoses connected to the single pump/reservoir are as in the picture? Mainly if I had the Cadillac valve and booster hoses swapped? I read on this forum that could be a problem.
Thanks in advance.
