4L80E error code 73 - trans light always on
RF5
Brazil
Hi there.
My 1988 Humvee M1097A2 (rebuilt by Army on 2013) with a 4L80E transmission and a 6.5L NA has the trans light always on as soon as the ignition is turned on and goes out after the ignition is turned off only.
I followed the DVOM procedures to check the error code 73 and realized that the pressure solenoid was with the resistance out of range (6.7 ohms). I replace de solenoid and also the internal harness, as the trans conector was full of oil. The oil is at the correct level as well.
The truck runs great and all the gears shifts perfectly, even before the PCS and internal harness replacement.
Anyone had this issue? Any idea how to solve this?
Thanks!
RF5
Brazil
Unfortunately not. The code 73 is still present, even with the new internal harness and PCS installed.
REF
135
Porterville Calif
My guess,
Check to make sure the engine RPM senor in the timing cover is hooked up so the TCM knows that the engine has started and to turn out the light. Without engine RPM the torque converter lock up will not work but you will have all 4 gears it will just feel sluggish. The original plug in the harness for rpm should be a 2 pin connector under the dog house on the drivers side sticking out of the main harness about the same level as the oil pressure sender on the engine. The sensor will be in the front timing cover on the drivers side just above the oil pan. I have seen times when they do a swap they don't bother to extend the wires in the harness to reach the new position of the RPM sensor.
Just takes a quick look, my best guess from this description.
Edit: Just saw you don't have a turbo engine, so the connector should be sticking out of the main harness about the same level as your heater temp controls.
NDT
7,420
Camp Wood/LC, TX
Supplement 7 sez:
DTC 73 will set when return amperage varies greater then .16 amps from commanded amperage.
ME: The amps sent by the TCM can vary from 0.1 to 1.1 amps. The amps in the return wire are out of spec. You must figure out why.
Supplement 7 sez:
Diagnostic aids: Check for poor connections at TCM and at transmission connector.
ME: check the harness between TCM and 4L80E for worn through insulation short circuits.
RF5
Brazil
Yes, I read the supplement, but the problem is how to identify the issue. Perhaps I need to find a specialist to check the wires. Anyways, thanks for the tips and valuable help. When the problem is solved, I’ll post here with de outcomes.
Just one additional comment. I noted a different behavior of the trans light when the engine is warm. I turned on the ignition, the trans light comes on. When I push engine start, the light goes out for 2 or 3 seconds and comes on again. This only happens when engine is warm. At cold starts, the light is always on after the ignition is turned on.
155mm
Chief and Indian
497
Guymon, OK
Did you read this thread?
REF
135
Porterville Calif
Crank position sensor (CPS), front timing cover - drivers side - just above the oil pan. used for engine RPM to the Transmission control module (TCM) uses 2 pin connector.
RF5
Brazil
One more question please. The CPS is present in both 6.5L NA and 6.5L turbo? I’m asking because I was told that 6.5L turbo only has the harness to connect the CPS and this harness is completely different of the 6.5L NA version.
Is that correct?
RF5
Brazil
Another question. The TCM installed in my M1097A2 6.5 NA with 4L80E and serpentine belt is the 2100BB. Is this the correct TCM model for a 6.5 NA? Or it is the 2100AA?
