Connected my MEP-803A the proper way as my home standby generator... Install pics...
Light in the Dark
6,802
MA
A better shot from another thread
RugerAC
Prosperity, SC
Hopefully I will get a reply on this question. I have the MEP-803A and I am trying to find a threaded female coupler for the exhaust so I can run it out of my pole barn. Have not had any luck so far in identifying it . Thanks
Ray70
7,194
West greenwich/RI
Your exhaust pipe is a standard NPT thread, 1 1/4" if I recall. I don't know what you want to use for pipe but a threaded pipe coupling or union will work.
An EMT tube coupling will work too. You just need to decide what and how you want to attach pipe to the coupling ( weld, exhaust clamp etc. depending on what you plan to use )
