Parking brake not releasing
Hanc
Ohio
Hello All
First time posting a question. After owning fixing a deuce (Lot of knowledge gained from this site )decided to buy a LMTV M1078 its 1995 built unit. Had visual issues but started and drove fine. Bought it, got it delivered drove it into the front yard and a day later tried to move the unit to the shed which is on top of a hill truck will not move. Started troubleshooting all the visual issues are coming back to bite me park brake will not release.I'm aware of the common issue with LMTV with check valves and its on order. The previous owner blocked the vent port on the brake valve not sure why and I have a mysterious hose with a valve which I cannot trace back leaking air all time and leaks a lot of air when brakes are released possible connected to something else to vent its soft to the touch and metal wire wrap around it. My question is can any of you can identify and tell me where its going or coming from. I'm reading the TM's it will take me some time before I find it. Any help is appreciated. Thank you in advance. I have attache pics for reference.
Ronmar
8,358
Port angeles wa
Allrightythen…
The pic with the short hose and pipe fitting and cap is your treadle valve. That capped line is connected to the valve vent. The treadle valve gets primary and secondary air from the tanks, and when you step on the pedal sends regulated air(more foot, higher pressure) to the primary(rear) and secondary(front) brakes to apply service brakes. When you let off the pedal, the treadle valve vents air thru that vent to lower the output pressure and ease/release the brakes. Capped like that your service brakes will never release… remove the cap. It should only vent air when you release the pedal. If it is venting continuously, remove the treadle valve clean and inspect it inside and either overhaul or replace it… sometimes the internal supply valve seat gets dirty and it allows supply in and this passes right out the vent with no pedal applied…
The last pic with the valve on the spiral line look like the vent hose. that line actually should be connected to the treadle valve vent. The park valve vent and the treadle valve vent are T’d together behind the heater and vent thru a floor port in front of the heater down in front of the radiator. If you remove the grill or tilt the cab you should be able to see it on the underside of the cab hump at the very front. the only time you should get air on that line where that valve is, is when you vent park air to set the park brakes, and then only until the park air vents away. A steady leak on that valve = a bad park control…
When standing beside the truck if you open the cab door just inside the door at eye level is where the pri and secondary air enter the cab to the treadle. There is a 2way check valve there that samples both and sends whichever is greater over to the park control valve. Your air pressure sensors are also there.
over at the park control, when you push it in, it sends that pri/sec air from the door 2way, to the trailer valve to enable it, and down to a 2way check under the drivers floor, then back to the anti compound valve above the rear axle. The anti-compound valve is a relay and seeing this air on its input, applies air down to compress the park springs and release the brakes. The 2way under the drivers floor(uppermost of 3) allows the red front glad-hand to also release the park brakes from a towing vehicle. There is also a pressure switch there that lights the park and emer lights in the dash…
When you pull out the park control, it cuts off the supply air and vents the air in the line down to the anti-compound valve out of that vent port behind the grill And turns on the park/emer lights in the dash. The anti-comp valve seeing this pressure drop on its input, copies it by releasing the spring air and the springs then re-apply park brake force setting the brakes.
i have done a couple vids on brakes over on youtube. Watch the brake overview and the front glad-hand delete vids. There are a few other air system/brake vids, I guess I should do a treadle valve video to complete the set:)
Here is the rear air brake component video, you should be able to find the others from there…
Hanc
Ohio
Ronmar thank you a bunch for the explanation. The guy who owned was 72 yrs old and he drove to work like that. I did take off the cap from vent of the threadle valve now the truck moves but I’m getting continuous air from the vent line will do the troubleshooting. Thank you all I have something now to start and look for and fix.
Hanc
Ohio
Yea when that spiral line is connected to the treadle valve vent all that park vent air should go out the floor port above the radiator…
I know I’m asking for more. What makes that hose vent all the time when engine is running or off and vent a lot when park brake released. I hear air from emergency glad hand venting too non stop.
Ronmar
8,358
Port angeles wa
The treadle/pedal valve vent and the park valve vent are tied together to the floor port. Air constantly coming out of them indicates a bad treadle or park air valve.
Air coming out of the red/emer glad-hand could be from 2 different sources. That gld-hand line splits and goes 2 ways. One is thru a check valve that feeds air to the wet tank to charge the towed vehicle air system when being towed so the vehicle brakes can be remote controlled by the front blue service glad-hand from the towing vehicle.
the second path is to that top 2way checkvalve under the drivers floor/behind the grill. This path allows the red glad-hand to release the park brakes. If the red glad-hand vents when the park brakes are released, the 2way is leaking. If it vents when the engine is running but park brakes set, that normal check is leaking back air from the wet tank. That check is located down in the bumper directly below the red glad-hand. I show it in the front glad-hand delete video…
Hanc
Ohio
Thank you. I’ll report back when fixed.
Hanc
Ohio
Thanks again Ron. Truck is up the hill in my shed I still have the leak when parking brake released will swap out parking brake valve and connect all hoses as it should be. Was nervous before I posted the question and I'm confident I can fix the issue. Thanks once again.
wandering neurons
147
Fallon, NV
If you're looking for odds and ends to troubleshoot/repair this issue, I'm parting out a M1078 cab following my recent cab-swap ("What have you done to your LMTV lately"). I pulled good parts from the old cab into the new cab. Parts from the new cab are available but untested. Treadle valve assembly, pressure transducers, air brake valves, hoses, CTIS manifold, etc. Willing to swap for cargo bed parts...
Rat-bastard children of the renters where the cab was stored broke all the glass on the gauges though. Then the rental house burned up. Was a good thing, they pretty well trashed it in the six months they were there. Insurance fixed the rental and I sold the house.
Hanc
Ohio
Just want to give a update on repair so far. Put new valves & fittings, in process removed heater just to see the exhaust setup. Found some interesting plumbing, someone had plugged the exhaust itself outside above radiator. All said and done I think I might have a check valve issue. I'm getting back pressure from parking brake line (i.e. delivery from park brake valve) seems like some might have connected directly to the tank. Hunt is still on. Zip file IMG_3967 is the air leak video.
wandering neurons Thanks for the offer will reach out if I need any parts.
Hanc
Ohio
Hi, Do you have wind shield wiper fluid reservoir with pump assembly ? Let me know. Thank you.
Hanc
Ohio
Ok here we go, should be the last post from me here, many more to come for other issues lol. First of all thank you Ronmar and everyone else for helping me to start the troubleshooting. The truck is fixed running and stops great. Had issues due to water in line & shady fixes. NOS parts etc, People buying new truck check everything before you buy. I would like to recommend everyone drain there tanks or end up spending money changing parts. Checkout pics. Also beware buying NOS, check before install got bite there too. Thank you all. Have a good one.
