LS swap lower radiator hoses????
sail78385
200
Charleston SC
All, I acquired an unexpected project vehicle that is a m998 with a 6.0 and 4l80 swap in it. I'm curious what others have done for a lower radiator hose from the water pump to the radiator. I've got a few hoses that are questionable and leaking and just thinking there has to be a better way.
sail78385
200
Charleston SC
All, please see the photos of the Humvee lower radiator hose and give me some input. I just feel like a 90 elbow is going to cause issues…. I think finding a rotating thermostat cover and getting a different hose would be best and maybe also modifying the lower radiator tube.. Just curious if anyone has any first hand experience.
Anvil Motorworks
Castroville TX
I would use a swivel neck then modify the factory lower coolant pipe.
Here’s a pic of my setup for an LT engine. I did away with worm style clamps and switched to tension clamps for all my coolant lines.
TurboR1
Utah
I know this is an old thread, but I wanted to share what I did on my ls swap. Gates 20837 radiator hose trimmed to fit with a swivel thermostat. The end is 2" to 1.5" with a slight bend.
