- 195
- 159
- 43
- California
I'd like to do a bit of welding and a bit of plasma torch cutting on my M1088 A1
What do I need to do to avoid killing the ECU?
There are two battery cutoff switches. One under the dash that works a relay and a manual battery cutoff switch at the battery box.
If I cut out the battery using those switches, is that enough? Or do I need to disconnect the batteries completely, physically?
