m1165a1 transmission electrical help
Jwf
Usa
ok so I was able to pin out j Z and a from the wiring diagram I had to order some test leads before I try to test it but I have them identified at least. however when the tcm is plugged in everything on that harness gets ignition power 4 get 24 and 2 get 12v with the tcm unplugged 3 of them loose ignition power 2 of those are going to the pins. also I believe it was j has continuity with 2 wires in the harness neither of which is clean one is 6 ohm the other is 12 ohm
