Thanks for your reply. It appears that you are more knowledgeable about slave cables than I am, so I will follow your advice. I had planned on simply re-routing the 2/0 OEM cables from the slave port in the grille to the side outlets of the new Hawker battery in the rear tray instead of to the 24v firewall buss. I have already labeled the grille plug 12v. Interestingly, on my M1028 there was not a resistor in that OEM circuit. I can certainly install a resistor in the new 12v wiring but would prefer a circuit breaker instead. I used an Eaton 187200-F-03-1 200 amp circuit breaker for my Sherpa winch and really like that device. Regarding the jumper cables, would you recommend using an OEM slave plug & cables with after-market clamps at the other end, or instead sourcing a heavy-duty set of non-military jumper cables to which the male grille plug is attached? Having fought jumper cables for 60 years, I prefer the small-stranded type which are more flexible in cold weather. And yes, PayPal works for me. I look forward to your next reply.
