Single out on stock wheels and tires
Dylandeuceman95
23
Laporte Indiana
Hello everyone, so eventually I’m planning on replacing all the tires on my deuce and singling it out on larger tires but will probably keep the stock rims when I do, I understand I can do this if I flip the rear hubs and run the wheels dish out. My question is, has anybody singled your truck out on stock 11.00x20 tires before. The idea here is to at least get the hubs serviced and flipped around and to get rid of a few old tires in the meantime time before buying the super singles. Just wondering if it’s been done and if so does it look goofy as all hell or halfway decent.
msgjd
4,121
upstate ny
all i can tell you is in the early 2000's a motorpool i drove past had a couple M35A2's that they singled out just by removing the outer duals and left the inners facing inward .. The trucks looked goofy as all hell :rolleyes:
idk if this works but if there was an opportunity to grab a set of six special-single rims w/1100x20's from a M135 (gmc hydramatic) or (rare) M34 , if that gave a tolerable wheel setting it might save you the bother of flipping hubs etc , but i don't know, have not done it, have not seen it
I singled-out my M49C while i am parting it out, flipping the inner wheels around to face outward.. It doesn't look bad at all but to run a loaded truck this way puts a lot of leverage/strain on the bearings .. If you just want to run empty around town on occasion, i believe you could get away with just doing this for the time being while you are waiting to do the super singles
G744
4,152
Hidden Valley, Az
M34 and M135 wheels were designed to run as singles with rear hub flips. The most tedious part is pulling and reinstalling the wheel studs. They will accommodate up to 12.00-20 tires.
Dylandeuceman95
23
Laporte Indiana
Thanks guys this was helpful. Especially 98g’s picture. And I don’t haul much with it, firewood occasionally but that’s it. It’s mainly a tool around town because it looks neat truck for me. That doesn’t look terrible. Just a little different. May be ok until I can buy those supers. Correct me if I’m wrong but if I want to run the stock a2 rims with supers I do have to flip hubs and flip the outer wheel correct?
HDN
5,576
Finger Lakes Region, NY
I have a stud installation tool I got for my 1-ton van. It's a thrust bearing with which you use an impact wrench and a suitable nut to pull the stud into where it belongs. It's similar to this: https://www.lislecorp.com/specialty-tools/truck-wheel-stud-installer
The thing that would probably annoy me the most are the locking wires that go between the bolts that fasten the hub to the brake drum. Though some trucks didn't come with that setup :unsure: My M35A3 does.
98G
Former SSG
4,905
What size super single do you intend?(this probably means a wheel swap as well.)
HDN
5,576
The M34 and M135 trucks ran single 11.00x20 tires, which Google says are about 43" in diameter. They fit on stock deuce rims. The super single about the same diameter is a 365/80R20 or 14.5R20, which is what the M35A3 was built with, but that's a wider rim too.
I think the 11.00x20 is worth looking into.
Dylandeuceman95
23
Laporte Indiana
So basically if I just flipped my hubs in the rear and ran the rear wheels dish out on stock 11.00x20’s it should look more or less similar to an m35. Because 11.00x20 military tires are what I currently have on it.
HDN
5,576
I think it would look more like this, but with regular deuce rims:
That's a Canadian-built deuce, which I think had a Cummins diesel, an automatic transmission, and bolt-together rims.
98G
Former SSG
4,905
If you flip the hubs you can run dish in.
Flipped hubs + dish out = considerably wider than the pic I posted.
  • Like
Reactions: HDN
HDN
5,576
Or 12.00R20
That's closer to a 395, which is about 46 inches in diameter. 12.00x20 tires seem to be between 44 and 46 inches.
Based on what we've talked about so far, bigger tire options for running singles on regular deuce rims are:
  • 11.00x20 tires, which are close to the 14.5R20 or 365/80R20 at about 43 inches in diameter
  • 12.00x20 tires, which are close to the 395/85R20 tires at 44-46 inches in diameter
The 14.5R20 (365/80R20), and 395/85R20 tires can be run on M35A3 rims, but not regular deuce rims. I currently have 395s mounted on my A3.
Does anyone know if the 11.00 or 12.00 tires will fit on the spare tire carrier? The A3's tire carrier had to be modified to accommodate the 14.5R20.
Dylandeuceman95
23
Laporte Indiana
I like the idea of that. Just trying to get rid of as many tires as I can so less to
Awesome info thankyou very much. Forgive my ignorance but when you say 11.00x20’s are you referring to the stock military tire size or is there a similar civilian 11.00x20 that I’m not aware of
williamh
714
SanDiego Ca.
I singled out my Duce years ago and used rims from a M-135. Flipped the hubs ( I used a press for the studs) and used 11.00X20 tires. The 11.00X 20 tires will fit in the spare tire carrier but won’t work with the M-135 rim. The offset prevents it from pulling up high enough to lock.
