Searching for the right LQ-2 Valve WCDFAPL-100
xGROMx
OBX, NC
I noticed the secondary draining at a stop light and could hear the air in the intake. After seeing Wes Simpsons (thanks Wes) video on it I went out and made sure it was it, yep the front LQ2 valve is done.
Now to find one with the threads on the exhaust side. Does anyone know where to get one or have a part number that can be found at a parts store? I see the ones on Ebay but I cant see if its threaded on the exhaust side.
Any help would be great, Thanks.
LQ-2
WCDFAPL-100
juanprado
3,215
Metairie/La (N'awlins)
They are out there. Eastern, Erik's, Big Mike's show the part if you want military Surplus.
I believe all Air Brake system parts for the M939 are civy parts and any good HD counterman at Truck Pro or NAPA or such can get you a new haldex formerly midland part. Haldex and Bendix also offer some valves as rebuilt. Haldex also typically has the rebuild kits.
xGROMx
OBX, NC
That's good to hear, I need to contact them.
I haven't bought the one listed because it states it is not threaded on the exhaust port.
From listing:
AFTERMARKET QUICK RELEASE VALVE / LIMITING VALVE FOR M939 TRUCKS THAT HAVE ABS BRAKES. THIS LQ-2 VALVE MAY LOOK SLIGHTLY DIFFERENT THAN WHAT IS ON YOUR TRUCK BUT WILL MOUNT AND FIT MOST LINES. ONE PORT FOR THE EXHAUST IS NOT THREADED.
xGROMx
OBX, NC
Thanks for the update, they are out of stock. I have looked in the normal places. I need to call the places and see if there are alternatives or time frame of stock.
This truck is at a fire station and used for storms, which we have had a plenty of lately here on the OBX.
charlesmann
713
Temple, Tx
I ordered from big mike and it the exhaust port isnt threaded. Talked to big mike via email and he said to just let it vent instead of plumbing into the system.
