factory tach install will it work?
48cj2a
34
Central, IL
Thank you for your generosity Gene!
The eBay links are still broken and they freak out on here when you post one:shrugs:
Just search eBay for: CUSTOM-PROGRAMMED-TACH-ADAPTER and see post #57 for more info on the correct options
Sharecropper
948
Paris KY
Hmmmmm........ I thought it was against the forum rules to post links to any Ebay auction. Am I wrong?
MarcusOReallyus
811
Virginia
You can mention eBay (some people seem to think even mentioning it is forbidden!) and I'm 99% sure you can even link to a SELLER'S STOREFRONT.
The rule is NO LIVE AUCTIONS. That includes eBay or anywhere else.
antennaclimber
893
State College, PA
From the Rules:
Auction Postings:please abide by the following rules concerning the posting of auction information in the forums:• Do NOT post about future or current GL/GP(GovPlanet)/GSA/eBay (including items for sale in buy-it-now formats)/local/city/state/Federal/estate auctions. You may post about any auction after the auction is closed.• Do not post links to auction photos. • Do not post links to GL/GP(GovPlanet)/GSA(or other sites)that have links that quit working after a short period of time. Save the image to your PC and then attach it to your post.• Do NOT post links to current eBay auctions or Craig's List ads that are not your own. You may post a link to your own auction/ad only if it is in an information/discussion thread about your vehicle/item. Do not start a post in the Conversations forum or your vehicle specific forum just to announce your auction/ad. • No collusion as specified above.
No E Bay links are permitted including the Buy It Now.
Rutjes
272
Amersfoort, The Netherlands
I almost ordered one with the same specs as Winston, but I'm in doubt now. I'm going to change to a 6.5 which currently has a serpentine belt drive with one (smaller) alternator. Not sure if I will keep it that way or convert it to the CUCV belt system with dual alternators. If so I will also need to make sure the pulleys are still original I guess. Maybe I should get a universal one or wait until I know for sure what I want...
GKGoodCheapParts
Little Rock AR
Sorry all, didn't realize about the links, it never occurred to me that they might consider a buy-it-now to be an "auction". The links should still work if you copy and paste them, or you should be able to email me via the forum, I made my addy public. For Rutjes, if the alternator phase count (pulses per rotation of the alternator) and both pulley rolling diameters (alternator and crank) are the same as Winston's, then his ratio should work. The length of the belt (dual or single alternator) has no effect on things, only the rolling diameters. If they differ from Winston's, you can do the same thing he did, use a Universal to find the right ratio and then get a custom based on the results. Winston kept his Universal, but I'll always take a return for credit as long as the Universal is fit for resale and not banged-up (of course, postage from the Netherlands might make that less desirable).
MarcusOReallyus
811
Virginia
Well, you could argue that a Buy It Now is not an auction, and you'd be right, but how would anybody police that? A mod would have to go to every eBay link and examine it to make a determination. No way they have time for that, so....
That probably explains why I was wrong about the storefront links, too, though I have seen it done.
GKGoodCheapParts
Little Rock AR
True. I understand the concern, it's fine. However, some of our products would be uniquely useful to people here, and for the record, we're a reputable vendor with good feedback who stands behind what we sell. So anyone worried about e-shennanigans shouldn't worry. Now y'all know where to find us.
ssdvc
639
CT
If anyone has a spare one of those tach units laying around, I would be interested. This looks like a very clean mod to a stock truck.
OP, It looks like you have done other mods to your truck, but in a stock 09, after one installed the tach, would all the other gauges/warning lights work as designed?
Sly
Boucherville
Here are some photos detailing where I needed to cut the stock dash, and how the unit is wired up. You will need to purchase a tachometer adapter from Widget Man.
They can be found on E Bay under CUSTOM-PROGRAMMED-TACH-ADAPTER
The unit will need a ratio of 1 : 5.33, with a 12 Volt output. 1.5 millisecond blanking time.
When you wire in the tach, do not tap into the ignition 12+ wire in dash wiring harness, when the glow plugs cycle, it kills power to the dash, so the tach will read zero when the glow plugs are lit or cycling.
Here is where it hits and where I had to cut out, you do not need to cut the circuit board. I used a dremmel with a cutting disc:
View attachment 750244View attachment 750245
Here is the wiring. I took the diagrams off the site here, but I'm not sure if they are 100% correct. You only need to worry about the fuel sender input, ground, and hot. The tach is wired separately. I grounded to the grounding block/terminals under the dash. I did also buy a small brake light indicator and put that up between my voltage gauges. Just tap into the brake light wires if you want to add that. Fuel sender wire is terminal 18 on the board, and the pink wire in the harness. I added a second tank, so that's why I showed it switching in the video. Don't worry if your tach doesn't have the wiring plug, it will work with just normal spade terminals. The tach is clearly marked, so you won't mess it up.
View attachment 750242View attachment 750246View attachment 750248View attachment 750249
The tach has a jumper, and I broke mine. So, I soldered wires to allow me to test the different positions. Use the jumper position shown, or do what I did below and just connect the 2 wires. If you don't have the jumper, or yours is in the wrong position, be sure you take off the plastic backing plate or you will break the jumper trying to get it out. If you are installing the jumper, make sure you have the metal tab under it, or it won't complete the circuit. In the picture below, you would want the red and white wires to be connected. I was doing some testing, that's why I made it so I could change the circuit without taking the dash back out.
View attachment 750243View attachment 750247
Hello! i'm new here and Gene refferd me to go here to find good info to swap my fuel gauge to C60 tach/fuel combo! big thx to you for all the right up gonna help me a lot! :)
frank8003
4,978
Ft. Lauderdale, Florida
From the Rules:
and this got changed too
Sly
Boucherville
no more old diesel board...welcome new and improve technologie! ;)
Edit: Installed and works great...even with LS engine swaps no need for resistor or other adapter! ;)
