Page 2 of 12 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 11 to 20 of 112
Thread: M134 Minigun build.
  1. #11
    4 Star General maddawg308's Avatar
    Join Date
    Mar 2006
    Front Royal, VA
    Posts
    10,721
    Thanks
    826
    Default
    I had a M134 minigun parts kit several years back, all the parts except the receiver housing. Cost a pretty penny to assemble the package, and sold for same. I wish you well in your dummy gun build, I've seen a few half-assed replicas and they just didn't look right. It's a complex design to replicate without patience and time to get it right.
    Mike
    maddawg308
    avatar: Jayne Cobb from TV show "Firefly"
  2. #12
    4 Star General glassk's Avatar
    Join Date
    Dec 2011
    Hampton, GA
    Posts
    1,004
    Thanks
    263
    Default
    http://www.replicaplans.com/M134-Minigun.html
    not an endorsement, just googled it
    The replica can be fitted with motors to spin the barrel
    12 Volt Trailer Wire & 24 volt Electrical Tape GROVE SM31AS Maintenance Platform M60 60 amp Dist. Box
    M116A1, Mep002A MEP 026D,Fluke 51 K/J Themometer,M116A ,Rothco Military 100 Mph Cloth Duct Tape ,
  3. The Following 3 Users Say Thank You to glassk For This Useful Post:
    Another Ahab (11-28-2013), Jbulach (03-09-2017), swbradley1 (11-26-2013)
  4. #13
    4 Star General Flyingvan911's Avatar
    Join Date
    Mar 2010
    Kansas City, MO
    Posts
    4,646
    Thanks
    963
    Default
    I would like to build a replica TOW launcher for my new but still squashed MUTT. I'd make it able to fire model rockets.
    It is a poverty when a dictionary must die so a person may spell as they wish.
  5. #14
    Colonel vitamink's Avatar
    Join Date
    Dec 2012
    Indianapolis, IN
    Posts
    201
    Thanks
    12
    Default
    Subscribing. I purchased a minigun replica from killbuckets as a base to build upon. It spins with 12v and it's mostly PVC pipe. I need to come up with a way to make that offset side mount and ammo chute.
  6. #15
    3 Star General General Mcgregor's Avatar
    Join Date
    Apr 2010
    Dover, New Hampshire
    Posts
    975
    Thanks
    333
    Default
    So I got the first barrel plate built. I am not sure if I am going to use this one on the final assembly or just use it as a marking tool.
    This is the first of five such plates that will form the barrel assembly, two more will be identical to this one and the last two will have a smaller inner diameter (3/4") for the drive shaft and have larger barrel holes to accept the larger tube.
    The specs on this plate are as follows:
    Overall diameter - 4"
    Inner Diameter - 1"
    Plate thickness - 5/32"
    Barrel hole size - 3/4"
    Barrel hole angles - 60 degrees
    -GM
    Attached Images Attached Images
    1972 M35A2C HT W/W
    Dualed G177 11.00s
    M66 Gun turret
    Convoy Lights
  7. The Following User Says Thank You to General Mcgregor For This Useful Post:
  8. #16
    4 Star General B3.3T's Avatar
    Join Date
    Apr 2008
    SW Ohio
    Posts
    1,234
    Thanks
    229
    Default
    IRACinc already does an awesome Mk-19 and M-2HB. A M-134 is tougher than most realize. Good luck with it.
  9. #17
    4 Star General Al Harvey's Avatar
    Join Date
    Apr 2013
    Dover, TN
    Posts
    1,154
    Thanks
    2,938
    Default
    Looking good. Can't wait to see the finished results.
    1974 M151A2, 1968 M274A5; 1942 GPW; 1952 M38; 1953 M38A1
    1971 M35A2 Wo/W; 1954 M35A2 W/W; M416; M101 x2
    1984 M1009; 1986 M1028A1 w/887 Contact Box; M1010; M1008 x2
    M1028; 89 Honda XR250R Military Dirt Bike
    "In the beginning of a change, the Patriot is a scarce man, brave, hated and scorned. When his cause succeeds, however, the timid soon join him, for then it costs nothing to be a Patriot."
  10. #18
    Sergeant
    Join Date
    Mar 2009
    Ringwood, OK
    Posts
    67
    Thanks
    224
    Default
    Subscribed.
  11. #19
    4 Star General F18hornetM's Avatar
    Join Date
    Jul 2011
    Ocean City, Md
    Posts
    1,123
    Thanks
    213
    Default
    Awesome project. Will keep eye out for more pics. I built a M2 was pretty easy and posted some pics here.. http://www.steelsoldiers.com/showthr...t=#post1205163.
  12. The Following User Says Thank You to F18hornetM For This Useful Post:
    General Mcgregor (11-26-2013)
  13. #20
    Join Date
    Apr 2010
    Posts
    975
    Thanks
    333
    Default
    My first goal is to have the barrel assembly parts cut, precise measuring and repetition is crucial at this point. Any incorrect alignments of the barrel plates or uneven cuts in the tubing will result in an ugly imbalance at 2500 rpm. All things being equal I wouldn't have to worry about balance issues beyond measuring, but chances are the rotational assembly will still require some fine tuning and the addition of some hidden counterweights.
    Believe it or not I think this will be the easy part. For the most part I know exactly what materials / parts I am going to use for this step. What I am having a hard time wrapping my brain around is the body of the gun, location/type of motor, and construction of the feeder/delinker assembly.
    I may have to use some fat PVC pipe for the body but I am currently searching for an alternative.
    The motor will either be 12 or 24 volt (Maybe 120vac if I decide to buy a power inverter, still unlikely) and will probably have a sprocket with a chain drive to the rotational assembly main shaft.
    The spade grips and trigger buttons should be pretty straight forward.
    Not sure yet what I am going to do for the mount, probably going to look like the one in pic #1 of my first post. The side mount looks pretty complex but I may be willing to give it a shot if I find some suitable parts.
    Feeder/Delinker is going to be tough...
    1972 M35A2C HT W/W
    Dualed G177 11.00s
    M66 Gun turret
    Convoy Lights
Similar Threads
  1. V-100 with M134 Minigun
    By B3.3T in forum Cadillac-Gage V100
    Last Post: 09-12-2010, 02:58
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
