dilligaf13
- 26
- 28
- south, florida
So I'm getting air leaking into the air intake stack but it's when the parking brake is released, not when the parking brake is applied (as indicated in the TM). This is causing the primary and secondary air systems to bleed down. When I activate the parking brake the leaking stops and air pressure in both systems builds right up to normal. I've replaced the treadle valve, with another unit from a working truck. Reading the TM the only other thing that it lists is the one-way check valve. I'm going to try and pull it off and take a look at it tomorrow. It's obviously hard to tell, when the truck is running, but it almost sounds like air is escaping somewhere near the parking brake. I've hooked shop air up but it wasn't much help tracking the issue down. Anyone else have a similar issue? Thanks.
