- 4,060
- 2,728
- 113
- Near Austin, Texas
That was one that looked and drove as if they had pulled the driver out, and stuffed it straight into a container, after throwing a folder with all the maintenance books on the seat. When it came out of the container, we put in fresh fuel (drained for shipment) and fluids, started it (the batteries were still good!), and drove it onto a trailer. Once home, anything that MIGHT need replacing in the way of fuel/brake lines were done, though all looked to be in very good shape. Been driving the thing ever since, with standard maintenance here and there.That price is right:
- that was a ready-to-run machine; fully functional?
As far as Swiss Mogs were concerned, as L1A1 said, I never saw a scrap one for sale over there. Most of the Swiss vehicles were kept in warehouses or hangars when not in use, and the Swiss don't salt their roads in winter, so the trucks tended to be in very good shape with very little rust (which Mogs seem rather prone to), much better than most of the other European nations' vehicles.
My part of the hive mind tends to think that there are a lot of 404s out there, so a frame off of a common type would have to be a personal choice. For a rarity such as a SWB Frenchie? I think it well worth the effort.
Having taken a V100 from a rather basic hull to a roadworthy vehicle, it will be waaaay more work than you thought it would be at the start! Is it worth it? Only you can answer that. For me, to have my dream vehicle, and one of less than twenty in private hands, the answer is "absolutely!!".
Cheers
PS - to fit the Swiss Mog into a container, the front bed bow had to be cut off, as it is fixed and too tall (barely, darn it) to fit into a container. Rather than weld mine back on, I made angle iron brackets and drilled holes so I could bolt it on/take it back off, as desired. You can see the cut frame behind the cab in the attached photo.
Mine is the only Mog I have ever seen in that camo.
