Page 5 of 5 FirstFirst 1 2 3 4 5
Results 41 to 45 of 45
Thread: Deuce Crash - Subway drive thru.
  1. #41
    Sergeant Major chestypuller1371's Avatar
    Join Date
    Nov 2015
    Butte Alaska
    Posts
    117
    15
    Default
    sure would be nice to have safe break option. i dont drive mine on the road, if it had better brakes i might tho
    1967 kaiser 2.5 ton multifuel turbo knaphoist dump addition to troop carrier.
  2. The Following User Says Thank You to chestypuller1371 For This Useful Post:
    98G (11-06-2017)
  3. #42
    4 Star General
    Join Date
    May 2013
    Posts
    4,138
    2,612
    Default
    Quote Originally Posted by chestypuller1371 View Post
    Later Air force and all of the A3's had a dual circuit system with two air boosters.
    I was reading about it and they say the MC is hard to come by and that instead of cups, uses an X-section EDPM o-ring (#2-222), and are worth rebuilding due to being rare.
    There probably are a lot of threads on making an older deuce into dual circuit.
  4. #43
    Former SSG 98G's Avatar
    Join Date
    Aug 2013
    AZ/KS/MO/OK, varies by the day...
    Posts
    4,285
    6,573
    Default
    There are a lot of threads about converting to dual circuit, and the consensus seems to be that it just isn't feasible. See clinto's post in the deuce forum..
  5. #44
    4 Star General dmetalmiki's Avatar
    Join Date
    Aug 2006
    London England
    Posts
    4,534
    569
    Default
    (Quote). "Dumping the clutch after killing the engine probably won't do any good with a deuce, as if you rotate the diesel, it will just fire up again. The man should have been going down through his gears long before the stop, to guard against what happened here".
    I absolutely can not 'count on the fingers of any hand' the number of times I have NOT changed down TO THE SAME GEAR I started in. When coming to a complete STOP in ANY Circumstance. (In any of my trucks).
    One fact I keep stressing to ALL the members of our group is, Descend any hill in the SAME gear as you would travel up it.
    (As(This rule does NOT apply to my M45 530C..,(because it steams up most hills in high gear no problem!..)), I STRESS, irregardless of the trucks 'climbing ability', Descend FULLY prepared.
    DIAMOND T M20.
    M54A2 I.H. M62. wrecker
    M54A2 5 Ton (with Praga command station surveillance body fitted)
    M45 530C TFFT fire truck
    1942 Ford Jeep (with underfloor tulsa winch)
    1945 Willys Jeep (with V8 flathead Engine) And overdrive.
    Packard Staff car. (WW11. General Pattern Tribute).
    Ural Military Motorcycle.
    Ex Army Hyster 4 ton Fork lift.
    Onan 7.5 kw ex army generator.
  6. #45
    Join Date
    Aug 2006
    London England
    Posts
    4,534
    569
    Default
    [QUOTE=Wildchild467;1704826]It wasn't me! I crashed mine once and that was enough!
    Before Rebuild:
    Attachment 554293Attachment 554294Attachment 554295
    After Rebuild:
    Attachment 554296Attachment 554297Attachment 554298
    All credit to the fantastic job restoring that truck to it's former glory, (Or even better!).
    That, Honestly would have been beyond my wit to do. And the truck would have been (Found) "In the Parts bin"!
    DIAMOND T M20.
Similar Threads
  1. M3A1 Stuart Tank At The Arco Station and Subway
    By Steve Greenberg in forum Tanks, APC's, etc...
    Last Post: 07-21-2012, 23:20
  2. deuce running better after crash?!?!?
    By Deuce_and_a_Half_Dragon in forum The Deuce
    Last Post: 03-28-2011, 22:00
  3. Stranded at Subway - Deuce won't start
    By TheOxman in forum The Deuce
    Last Post: 05-26-2010, 09:57
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
