- 363
- 649
- 93
- Mansfield, PA
Looking for some input on the M151 front fender top design. This is the fender top only, not including what I would call the inner fender section (which is all one piece). When I made the fender tops for my A1, I stopped the inside edge (under the hood) at where the bend center line is. I'm going to weld the entire length and blend. When I'm done it will look like the original bend, or very close. The other option is to have about a 1" lip bent down that would lay over top of the inner fender and then get plug welded. I think most people would rather have the lip and do the plug welding. So that is the question, what do you guys think most will want?
Thanks.
Guy
Thanks.
Guy
