- 1,450
- 118
- 63
- Gray, GA
Hard to tell from the picture but it appears the light says 24v. This is most likely the problem.If I remember correctly the HET headlights are 12 volt.
I’ve used mine down to -6 and no issues.Has anyone used these in a cold/snowy environment? Do they generate enough heat to keep clear? As I write this it is about 0F and snowing sideways. Just wondering when cold... is too cold for these.
16 is ground 17 is low and 18 is highMy light terminals are labeled 16, 17, 18. How do those correlate to non military lights (+, -, ground)?
