0-80 electronic speedometer in a mechanical hmmwv
erasedhammer
56
Maryland
That is what the sender screws onto. The piece on left is held into t/c with a y bracket. The 90 degree piece will not be reused. If you pull the piece out of the t/c, you will need to get the tm out to see how to put it back in the correct position. This is also where you change gears for different diffs to get correct speed reading.
Will the sender not work if it's plugged into the 90 degree adapter? Mine is not working, not sure of the cause yet.
I had a spare t case lying around and I did basically what you said, I unscrewed the 90 degree adapter, but to my surprise there was a square drive rod sticking out which the sender will not plug in to.
So unless there's some other adapter that is needed the sender will not plug directly into my t case. I have a 242 in case anyone was wondering
erasedhammer
56
Maryland
Open up your Parts TM and learn what that little thing is. It isn't mysterious.
Well it looks like there is a separate adapter that is used. The TM shows the sender plugging directly into the transfer case. Unfortunately thats impossible as both the t/c and the sender are male connectors. So where would I get this different adapter?
UPDATE:
Took another look at the wiring diagram. There are three wires coming off the sender, one being a ground wire. I do not have this?
Is there only supposed to be one wire that carries the signal from the sender to the speedometer? or two?
86humv
488
Texas
You must have skipped page 2 of this post...mount and sender are there.
erasedhammer
56
Maryland
disregard that part, part of the 90 degree adapter stayed in the t/c making it look like the wrong gender connection.
But I got it working.
for 10 minutes.
then it broke again. All electrical connections are good to go. Ill be unscrewing and screwing the sender back in to see if something interally broke on the sender.
86humv
488
Texas
The plastic gear T/C housing has an adjustment depending on gear tooth count.
86humv
488
Texas
Tab comes out by pulling it....if its broke now, it was not when sent.
Also there are 3 different gears for inside : 35 teeth for 2.56 gears, 36 teeth for 2.73 gears, and 41 teeth for 3.08 gears in Diff.
The gear/sender housing must be adjusted to proper numbers per teeth.
Here.s pics.
papakb
1,186
San Jose, Ca
The unit is not a pulse generator, it's just a little DC generator. I have a couple of them and they output DC voltage when spun up with a drill.
wildchildsteel
el paso, tx
I have a 90 on my t/c with test leads coming out of it. I am trying to install a piece of equipment with gps and it needs to be able to tell if the wheels are moving at what speed, just like the speedo. but I need to know what kind of voltage I should be seeing.
