Page 4 of 4 FirstFirst 1 2 3 4
Results 31 to 38 of 38
Thread: Turbo classification...?
  1. #31
    4 Star General tm america's Avatar
    Join Date
    Feb 2009
    merrillville in
    Posts
    2,600
    516
    Default
    that looks like it but it doesnt whistle .and my motor says ldt 1d on the tag.was the m109 rebuilt in the 90s i wonder if they built them to different specs around that time .and maybe these turbos were a upgrade .or if they did them to lds specs .whats funny about these turbos is the exhaust side is similar to the c turbo but the compresser side is similar to the five ton turbo.all in all it looks like a five ton turbo.mine says swhwizer right below the tag .can you check to see if yours has the same tag numbers as mine
    m35a2c dump winch 15.5s
    expandible camper trailer
    m105 soon to be camper
    97 ram 1500 4x4
    ih2410b with 130hp mercedes turbo deisel
  2. #32
    Join Date
    Feb 2009
    merrillville in
    Posts
    2,600
    516
    Default
    recovery4x4 were you able to fine anything off of the tag number from my turbothis is really interesting since it would mean they actually ran three different turbos on the deuce not just twoand this turbo i have seems fas superior to the other based on the boost readings everyone is getting with the fuel turned up.there are a couple guys that said they had readings similar to mine but most have 11-13 as a max .i wonder if the ones with readings higher than 20psi have this same turbo as i doi would like to get some more info on it and if they did internal mods when using this turbo
    97 ram 1500 4x4
  3. #33
    Banned
    Join Date
    Mar 2009
    VA
    Posts
    494
    19
    Default
    I just checked and the part #'s are the same.
    The serial # on this one is 3LD-305/E2472-45
  4. #34
    Join Date
    Feb 2009
    merrillville in
    Posts
    2,600
    516
    Default
    i dont have a lds maunual to see if they are in fact from a lds427 if anyone can look up the number to see if it is or not that would be greatly appreciated
    97 ram 1500 4x4
  5. #35
    Join Date
    Feb 2009
    merrillville in
    Posts
    2,600
    516
    Default
    divemaster920 does your turbo whistle like the c turbo does mine just barely gives off any whistle
    97 ram 1500 4x4
  6. #36
    Banned
    Join Date
    Mar 2009
    VA
    Posts
    494
    19
    Default
    Tm for the 427 turbo is 9-2990-201-35....I looked in the TM's and it is not there.
    According to the pics in TM 9-2815-204-35 (427), this is one of the turbo's that it used.
    No, mine does not whistle like the "C" on my Deuce, but it does have a faint whistle to it.
  7. #37
    Sergeant Major monkster's Avatar
    Join Date
    Nov 2009
    Mt.Vernon, IN
    Posts
    144
    Default
    With out doing any search. Are these turbo' rebuildable, say from my tractor mechanic.
    M35 w/w
    M35 w/o (2)
    M814 w/o
    M820 (dump truck)
    M932
    M101A2
    M105A2
    Expandovan Trailer
    (4) "R" Macks
    78 cj-7
    MVPA 32905
  8. #38
    Sergeant Major
    Join Date
    Jun 2009
    Fuquay, North Carolina
    Posts
    176
    Default
    yes the fat compressor skinny turbine turbos are lds 427 turbos from what i hear they are rare....oddball turbo...mine runs 9psi of boost on cold day at 50mph gas to the floor..but my truck is stock. I can hear a faint whistle at idle and more when boost builds.I hve taken the upper part of the stack off for painting and it seems to spool up quicker with less exhaust pipe on the stack....ken knows alot about these turbos it seems like...he did a great job on mine
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
