M750 van trailer
1,814
Phil, not sure what you have there with those numbers but if it looks like the ones pictured above, I doubt you could get the tongue under 6000#. If it has the 5 load banks like mine used to have, add another 1000# to that total. I'd say moving a semi trailer with a pickup, might get you noticed.
4XDesign
47
Blythewood, SOUTH CAROLINA
I found a m750 chassis for sale. I'm unable to find specs on it. If any one has one available to measure. I'd like to know the length over fifth wheel from step up to the front. Also the king pin to front end, the frame length from step down to rear and height at step up and step down. Sorry I know it's a lot... thanks for any help
Scrounger
65
Southern, Maryland
The M750 trailer and the M447 trailers are M295 semi-trailer chassis with different boxes mounted. It is too cold and dark outside to take pictures of either my M750 or M447 trailers. However, I did find this picture of a data plate online.
4XDesign
47
Okay great thank you that's enough info for me to know my idea will not work on
that chassis.
simp5782
Feo, Fuerte y Formal
9,264
Mason, TN
Picked up one of these at auction for the cheap since Noone else bid on it. Luckily it came with all the cabinets. Sides opened pretty easy even after years of sitting.
No side panels though.
USAFNB
57
Xenia, Ohio
I'm jealous, Congrats Simp! I am still trying to get a hand shake on the one I found.
