Barrman
- 1,572
- 113
- Giddings, Texas
The one I posted has the correct thread main shaft.
THat performance part number just shows the puller and not the bearing or the large nut the installer has. Are you saying the main large bolt for the puller fits our cranks? If so then it would probably work if you found a m16x1.5 nut and large washer but the threads can't go as deep with that tip.The one I posted has the correct thread main shaft.
I tried to weld the 2 bolts together to make the installer but my crappy 110v wasn't penetrating. And nobody locally close to me sells a long m16x1.5 bolt.I used a standard puller to remove the old balancer . Then I just bought a long bolt, nut and used the washer from the old crank bolt to install the new balancer.
Mine was closed during the weekend. My fault for not preparing earlier in the week but I assumed the install kit would work. Two Ace HW stores had the nut, don't stock the bolts.I bought the bolt at my local Fastenal store.
