- 3,272
- 3,010
- 113
- Brooklyn, NY
Not only will you get to do an amazing engine/drive train swap, you will get to auction off a lot of stuff to re-coupe a lot of your investment.Got in the shop today and on the lift, turns out it has an AirDog II 4G lift pump filter setup, between the AMP motorized running boards, the Cheetah turbo and the AirDog I have more add on acc. than I paid for the truck by far, not even counting the 4" exhaust and the high flow intake which I will only be able to use very little of, also confirmed it was set up for DSP-5 which means it has probably been run really hard, the top of the fuel tank was pretty clean so it ptobaly did not see much off road activity
I think you got an awesome deal.
As far as being "run hard" , and the fact that she is a roll-over, with all these upgrades she might have been run hard and put to bed wet BUT she is a Duramax, so I bet she is fine.
If you're worried, run compression tests cold and warm. Also send the oil out to be tested for wear. I bet the engine will be perfect, but never a bad idea to check her out with tests. You can also try to contact the original owner and see what he/she has to say.
I would love to see how this turns out for you, because I would love to do this swap in the future.
I look forward to your future posts. Following this thread.
Best,
T
