Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: Red Dot A/C install help
  1. #11
    2 Star General LiveFreeOrDieTryn2B's Avatar
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    642
    Thanks
    255
    Default
    Ok guys I need help with fittings for the compressor I it's not here yet and no specs on the thread sizes need to get charge fittings for high and low sides of compressor and possibly some elbow fittings. Here's some pics of compressor.
    Attached Images Attached Images
  2. #12
    Colonel
    Join Date
    Mar 2016
    port allen la
    Posts
    292
    Thanks
    33
    Default
    C3CBB242-E978-4E49-8120-00E5F89E4BEC.jpgi had to tweak the hardware in my waterloo compressor kit, i don't remember the exacts but here is my post on it https://www.steelsoldiers.com/showth...=1#post2124297 i put washers behind the fan to get the blades off the compressor snout, still had to bend a little wiggle in the back side of each blade.
    haven't constructed the rest of the system yet as another project moved up front and now that its fall it may end up spring before i build the evap
    edit to add condenser fitment pic, it's a generic parallel flow kit with a drier/pressure switch and a few fittings, was 60-70 delivered
  3. The Following 2 Users Say Thank You to winfred For This Useful Post:
    LiveFreeOrDieTryn2B (11-14-2018), silverstate55 (11-14-2018)
  4. #13
    4 Star General M35A2-AZ's Avatar
    Join Date
    Nov 2010
    Tonopah, AZ
    MVPA
    34235
    Posts
    2,834
    Thanks
    774
    Default
    I have a number of fittings left over from all my ac installs, let me know what you are interested in any of them.
    Trucks: 43 Willy's MB, 52 M37, 71 M35A2 w/w, 84 m936, 85 M923A1, 85 M929, 84 M925
    Trailers: 66 M332, 92 M105A2, 08 M200A1
    Gen: 03 MEP-803A, 01 MEP-805B
    S-280 Shelter
  5. The Following 2 Users Say Thank You to M35A2-AZ For This Useful Post:
  6. #14
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    642
    Thanks
    255
    Default
    Ok guys here's another video going over the various parts,fittings and sizes.
  7. The Following User Says Thank You to LiveFreeOrDieTryn2B For This Useful Post:
    silverstate55 (11-15-2018)
  8. #15
    Join Date
    Nov 2010
    Tonopah, AZ
    MVPA
    34235
    Posts
    2,834
    Thanks
    774
    Default
    Here is a sheet I worked up when I was doing my trucks with the Humvee kits. Not sure about the #10 at the compressor it maybe a #12. Hope this helps.
    Attached Files Attached Files
    S-280 Shelter
  9. The Following 2 Users Say Thank You to M35A2-AZ For This Useful Post:
    LiveFreeOrDieTryn2B (11-15-2018), silverstate55 (11-15-2018)
  10. #16
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    642
    Thanks
    255
    Default
    I'll be starting to mount everything where's going to go today or tomorrow hopefully so I can get the lines made up.
  11. #17
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    642
    Thanks
    255
    Default
    Well started installing compessor and the belts are too short kinda figured they would be so have to take measurements and get new ones. I only had one other issue so far with a bolt but made a stud and got it to work. I ll get videos up as soon as new belts are aqiured.
  12. The Following User Says Thank You to LiveFreeOrDieTryn2B For This Useful Post:
    silverstate55 (11-16-2018)
  13. #18
    Join Date
    Oct 2011
    Ocklawaha FL
    Posts
    642
    Thanks
    255
    Default
    Ok guys I had to go through 4 different belt sizes to get the correct length. I had to change some of the hardware out and use shims. I also had to trim roughly a half inch off my nylon fan blades very easy to do with lexan hobby scissors. I have the duel voltage alternator and that pulley as well as AC pulley were bigger so needed different belts. The belts were 55" long. I got everything tightened up started truck ran at idle and very high rpm good to go. I won't know until all the system is hooked up how compressor with do with a load on it. I'll post a video or 2 tomorrow.
  14. The Following User Says Thank You to LiveFreeOrDieTryn2B For This Useful Post:
    silverstate55 (Today)
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
