transfer case rear output flange
m-35tom
221
eldersburg maryland
I need to replace the rear driveshaft output yoke. Is all the oil in the trans going to try to get out? Do I need to drain the entire trans first?
snowtrac nome
137
western alaska
The bearing is lubed with trans oil pressure there is a cavity behind the seal that will hold a pint or less of oil and that is all that's going to come out unless you start the truck.
m-35tom
221
eldersburg maryland
OK that makes a lot more sense but if it is lubed with pressure where does it drain away to? Will that passage carry oil in opposite direction? Sounds like if I do it quickly I will not lose enough oil to matter.
NDT
5,884
Camp Wood/LC, TX
Curious how the ear got broken off? Let me guess GP forklift rash? Hopefully the shaft is not bent or case cracked. Had to be an immense force to break that part.
m-35tom
221
eldersburg maryland
Drive shaft twisted off the rear u-joint then fell from under truck breaking one ear off the front flange. Did not hurt the shaft.
coachgeo
3,346
North of Cincy OH
Inspect close for cracks in Tcase housing and bell housing. Whatever caused the shaft to twist off..... before that finally happened must have been putting tremendous vibes thru all those housings...
tennmogger
529
Greenback, TN
Tom, I have pulled the pinion yokes a couple of times. Probably on the output shaft yoke the challenge will also be breaking the nut loose from the shaft, and pulling the yoke off the shaft. You'll need a good impact, or long cheater bar, of course. I had to make a 'puller' to pull the flange, a thick steel plate (3/8" I think will fit between the oil slinger/protective flange and yoke) with a U groove to fit down behind the yoke and a bolt hole in each of 4 corners, four threaded rods to cover the length of a hydraulic jack, and another plate at the base of the jack. Said jack laid on it's side of course to push on the end of the pinion. The yoke was really on there. The whole truck seemed to jump and the jack and puller became airborne when it came off, so beware.
I can look up the lube seal number if you want to replace it (the reason I pulled mine). The original was a two piece seal, replaced by a one piece seal. There's a thread on it. [edit, on second thought the transfer output seal might not be the same as the differential pinion seal that I replaced] YMMV
