- 6,426
- 4,979
- 113
- Ft. Lauderdale, Florida
Being military and shipyard with access to every "freer upper" inside and outside the system, and working on gettin things apart that others could not, and then finding Kroil.... I find there is only one maybe better.
Get the acetone and ATF and maybe and add 2% DOT 5 or DOT 3 and have at it.
Assure your tools are still as design. Heat is a welders solution, sometimes even works, but all the stuff I have worked on was special and one could not change metallurgy properties. Disallowed in ships and subs and aircraft.
In any case is the original poster problems resolved.
