1944mb
- 84
- 28
- Big Timber, MT
Greetings and welcome. Are both axles lockedup? I would start by jacking up one axle enough to get both sets of tires off the ground, then try and rotate by hand. If the wheels move a short distance, then stop, and you can reverse and do the same thing in the other direction its probably more drive train related. I'd pull the driveshafts cause they are best to move without driveshaft connected anyway. If the tires move freely it obviously drive train related. If they are froze solid you could try backing off the brakes. There are two adjusters per backing plate. 5/8" socket I believe. Rotate to the rear of the truck to back off. a turn should do it. Then see if they move. Let us know how it goes.
