Lighting system.
dmuldrew
Memphis, MO
I’m the new owner of a M998. I need to add a plate light to be legal. I haven’t checked yet. I know the ignition system is 24v. How about the lights?
TOBASH
2,994
Brooklyn, NY
All 24V. The great auction site has 'em.
springer1981
1,148
Maine
I went to a local auto parts store and bought a 12v plate light and asked the guy for a 24v bulb that fit. 3 minutes later I was on my way with a 24v plate light.
Milcommoguy
2,098
Rosamond, CA
That's the way to do it or snag a 24 volt bulb out of an old military lamp housing. Tap into existing tail lamp circuit, left or right side.
Save the online 50 bucks on a license plate set-up. You will need lots BUCKS down the road.
DIY and save, CAMO
Bulldogger
585
Quantico VA
Those Military Guys advertise here and have a 24VB license plate bracket with a light. I broke the light, backing against a tree for a trail brake, but I was able to replace it.
As noted, lots of options!
BDGR
HUNvee
236
Hungary
I bought a used motorbike plate holder, and changed the light to led. It was less than 10 bucks.
Used the existing holes to mount under the tailgate.
911joeblow
68
Utah
LEDs usually don't care if it is 12V or 24V so I use them whenever possible. They also dont fail like incandescent and use much less power too.
warcow105
Lincoln Park, NJ
*Some LEDs work great with 24v.
Look for ones that are 24v only. If you go for ones that say they are for 12-24, only get ones from reputable companies. Not all of them have active current regulators to deal with different voltages. I recently got one that went from around .3w at 12v to several watts the closer I got it to 24v... Well outside what I'm sure the LEDs were rated to handle. I pulled them open and found a simple current limiting resistor. Sure they would probably work at 24v, the question is for how long.
Mike
