kzeyus
- 30
- 28
- Rogers, AR
Need a little help with ID and info on a milemarker winch I wish to mount to front of my HMMWV. Been searching, but not finding much on this model. Note it's the reverse layout of the normal front winch with controls to right and motor to left when looking from front of truck. It did not come on this mounting plate - I put it there to get some measurements to see if would work in this reversed arrangement. Have not called Milemarker yet, but plan to do so next week.
What model truck did this come off of? Was it front or rear winch? I don't think it was a rear as all I've found had remote solenoids. Anyone have the install manual for this particular unit?
It has an extra Valve?, Bypass? or something hooked up to the hydraulic lines - what is this? I suspect a bypass of some type to return over pressure or something.
Winch labeled 19207SOCN12480535, the extra hydraulic piece appears to be 19207SOCN12506888
Can I mount this unit on front of M998 HMMWV? It appears by measurement the solenoids would clear the radiator hose, and would just need custom hoses.
Should I use or remove the extra hydraulic piece (bypass, return or whatever) on an 86 model M998 or use it?
