Olly
- 6
- 18
- Bristol/CT
Long question ; I have an XM818 it has the T-138 transfer case with the sprag. Now I know from what I've researched it has forward and reverse and I've also read that if the truck rolls backwards while in forwards or vice versa it will bind up and could break the transfer case or sprag or something like that. I was thinking about putting in the T-1138 from the M900 series I know that in low gear it automatically engages the front axle, and I also know you can disengage that and put it on it's own switch. My question is if I put the T-1138 in my truck and engage it with a switch would I have to worry about it rolling backwards in forwards or vice versa? I read that the gearing in the T-1138 is different from the gearing in the T-138. Thought about putting my transfer case on a hand shifter but the difference in gearing from what I read would make a mess quickly. Have a lotta snow covered roads in the winter and even more hills. Need to be able to engage 6 wheel drive when I need it and I read that the T-1138 acts more like a 4 wheel drive transfer case on the road with a 1 to 1 gear ratio. I'm not sure on that though so if I'm wrong would appreciate any information. Also on the T-1138 does it have a forward and reverse engagement or is it just engaged or not engaged? There is one other thing if the T-1138 is left in high gear can you reverse I know in low it's a big no-no? I know it was a whole paragraph but I figured ask once instead of a hundred small questions. Any information would appreciated. Thanks.
