Results 1 to 4 of 4
Thread: Coil test
  1. #1
    Private
    Join Date
    May 2017
    Nashville Ga
    Posts
    Thanks
    Default Coil test
    Does anyone know what the resistance on a 24 volt coil should be. I have 12.7 ohms on the primary circuit and 17.85 on the secondary. Problem is no fire at the points. Thanks
  2. #2
    General TGP (IL)'s Avatar
    Join Date
    Sep 2010
    Metro East IL
    Posts
    457
    Thanks
    1,344
    Default
    See if this will help.
    Click the image, then click it again
    Tom
    Attached Images Attached Images
    "99" Durango
    "99" Dodge 3500 CTD Dually
    "86" Chev M1028A2 Dually
    "84" Chev K 30 6BTA,400 3.73,No-Spin
    "77" Chev K 30 400ci 400,4.56, No-Spin
    "65" Kaiser M35A1 WW
    "54" Willys M38A1
    "52" Dodge M37 WW
    "47" Dodge WDX WW
    My Photo Album http://www.t137.com/cpg/index.php?cat=10010
  3. The Following User Says Thank You to TGP (IL) For This Useful Post:
    CMPPhil (06-05-2019)
  4. #3
    Private
    Join Date
    May 2017
    Nashville Ga
    Posts
    Thanks
    Default
    Awesome Thanks!!
  5. #4
    4 Star General Bill W's Avatar
    Join Date
    Jul 2004
    Brooks,Ga
    Posts
    1,967
    Thanks
    1,225
    Default
    if I remember correctly you don't want a coil that reads Below 9ohms otherwise you could start frying the points ( to hot of spark )
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
