Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 51 to 54 of 54
Thread: Fuel filters or lack thereof and stalling.
  1. #51
    Banned
    Join Date
    Sep 2011
    Woodinville, Washington
    Posts
    8,137
    2,290
    Default
    Now there must be ground rules for this bet. Since we where originally talking about this "none" running truck, your truck must be none running for a week. Also there must not be any "residual" pressure in the "Hydraulic Head". My truck will start on the first turn of the switch. That is just using the residual pressure in the HH. So all pressure must be released in the system. Then the relief valve must be removed and the plug reinstalled. With gauges in place to verify the pressure you will try and start your truck. No starter fluid is allowed.
    You know as well as I do that the booster pump will increase the pressure enough to help a truck idle once it is started. Even with a malfunctioning relief valve. The question is , is the in-tank pump enough to get the truck to start initially. So again no residual pressure is allowed in the system.
    Just a question first. Where did you get the idea that I was rich ? I was forced to retire on a limited pension. Yes my house was payed for which was a saving grace for my family, but we are not wealthy.
  2. #52
    Banned
    Join Date
    Sep 2011
    Posts
    8,137
    2,290
    Default
    For those who want to do this little experiment themselves, here is the valve we're talking about.
    Scan0166.pdfScan0167.pdf
    It is located between the filter canisters on the top of the filter assembly. You will either have a valve or a ball. Remove it and the spring. Reinstall the plug and try and start your truck.
  3. #53
    4 Star General Floridianson's Avatar
    Join Date
    Dec 2006
    Interlachen Fl.
    Posts
    5,911
    2,647
    Default
    Quote Originally Posted by rustystud View Post
    Then it was you who went to the moderators and had me banned.
    Before we get to the terms of the bet I think you better go back and change that to " I believe" it was you!
  4. The Following User Says Thank You to Floridianson For This Useful Post:
    Menaces Nemesis (06-24-2019)
  5. #54
    Administrator patracy's Avatar
    Join Date
    Jul 2006
    MVPA
    37424E
    Posts
    13,285
    1,222
    Default
    Enough of this. Next one to spout off gets a point. In any post going forward.
    M114
    1992 M1038
    1969 M35A2 wo/w, hoist in bed, heater, Ooga horn, Recentered HEMTTs and 395's, "Candy Smasher"
    1968 M543A2 Wrecker - You know, for heavy lifting...
    1984 M931 - SEMTT project
    198? M270 trailer TBD...
    1985 M1008 - SMOKEY 8" lift, 37" humvee 24 bolt wheels/tires, turbocharged.
    And a few M105 and M101 and other trailers
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
