MEP-803A no AC output
Hard Head
21
Greenville SC
Has he removed the front cover and looked at the tank / fuel pump? If the unit is working until prime is lost then there has to be a leak. Does the aux fuel system work?
DieselAddict
1,879
Efland, NC
That's my thought is there is a leak somewhere allowing the system to drain back into the tank.
Just for grins maybe remove and check the seals on the filters.
Guyfang
22,090
Burgkunstadt, Germany
Like you all, I think it has to be a leak. But could also be the flapper in the e-fuel pump, that acts as a "check valve". It happens, but not often.
Daybreak
2 Star Admiral
740
Va
Howdy,
Exactly. :)
Take a look at your canister filter. Make sure that little tiny gasket stayed in place on top of the cup when you re-installed it.
We are all saying this...and that.
I hope all filters were changed. Fuel cartridge filter and the fuel/water separator filter.
NOTE: after running, system itself is self bleeding. That is the sound change for the fuel pumps from a hollow sound to a full sound. All fuel pumps thru the system and back to the tank via fuel return lines.
Ray70
5,081
West greenwich/RI
Anything upstream of the primary pump shouldn't matter as far as drain back, and it doesn't sound like you are sucking air while running ( otherwise it wouldn't run smooth under load ) Just check from the primary electric pump to the 4 metering pumps and see if there are any issues or leaks. If everything is good and the filter and fuel / water separator are good, I'd suggest changing the fuel pump. If you still have the crappy square body pump, definitely get rid of it. An Airtex E8135 is a drop in replacement for the square pump. $35 on-line. If you have one of the round pumps with the 4" stainless extension line installed you will need some NPT x Flare adapters to make the E8135 fit.
Even with an air leak or a bad check valve in the pump, like Daybreak said, a good pump will self-bleed fairly quickly. My money says you have a failing fuel pump....
And like I said, if it's the old square body pump, get rid of it now... they are known as unreliable pieces of junk.
k9medic
14
Florida
Thanks all.
I borrowed a double oven today and put both ovens to bake at 400 degrees. After 2 hours and no hiccups, I turned everything off.
The generator ran great. I swapped out the analog hertz meter with a digital one and it held 240-242v at 60 hz the entire time.
The load meter still does not work though.
Here is a photo of the injectors though after I shut it down. Not sure what that might be -
k9medic
14
Florida
I agree it looks like oil seepage from somewhere. The engine was clean and dry when I started it.
I did swap out the worthless hertz gauge though. Now also thinking about getting a digital amp/load meter.
