Results 1 to 10 of 10
Thread: Am General M920 tire sizing
  1. #1
    Private
    Join Date
    Nov 2019
    Fond du Lac, WI
    Posts
    Thanks
    Default Am General M920 tire sizing
    Hi, we bought an Am General M920 for farm use, we will be using to haul liquid manure. We mounted a 4800 gallon tank on the back to do so. I have been working on tires for the truck and I had the rears retreaded with a more aggressive tread. The tread is BLSS from bandag, which looks like it will work really well. The one problem I have is finding wider tires for the front. I was going to use the Michelin xzl non-plus 395/85r20 but they are not able to retread that wide of a tire. The only reason I was going to have them retreaded was, so that all tires would hopefully be the same diameter. My question is would it still be okay to use the 395/85r20 or try to find a tire size that is closer to size? The diameter of the recapped 11.00-24s are 47.6 inches and the diameter of a new 395/85r20 is 46.8 inches. Is the diameter difference too much for the 8x6 Am General? We would only turn the 6 wheel drive on in the field. Any advice would be appreciated.
    Thank you,
    Grant
  2. #2
    I'm the dude, man! Steel Soldiers Vendor simp5782's Avatar
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,619
    Thanks
    108
    Default
    Will work as long as you use the front axle offroad only. Redo your power divider switch so you can have a switch for your power divider to pull on or offroad and a switch for the front axle engagement.
    2008 F-250 6.4L Powerstroke
    1979 AM General M920
    1984 AM General M915A1 (Big Cam III, HT3B Turbo, Brushless 24v Alternator with equalizer, A/C, Rear 20,000lb winch. 11R24 rear tires and 395s up front.)
    1984 AM General XM923A4 ( Big Cam III NTC-400, HT4B turbo, Intercooled, #10 button, Dual fuel Line setup - MRAP Aluminum Radiator - 7" Ram Air Intake system - Dual 115 gallon tanks - Air Conditioning - 145amp alternator - Puradyn Oil Bypass system, CAT 7155 16speed transmission, riding on 16.00 AT-3s on HEMTT wheels. )
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    M322 Equipment Trailer
    MEP-804A
    901-318-8353 for Help in and or around the Memphis area or transporting in the southeast. Text me first before calling.
    Tires (HMMWV, 395s, 1600s) and Transportation Vendor
    Wes
    Videos at https://www.youtube.com/results?search_query=5782simp
    https://www.youtube.com/channel/UCTd...D4dOJidPFnmYGA
  3. The Following User Says Thank You to simp5782 For This Useful Post:
    silverstate55 (11-10-2019)
  4. #3
    Big Dummy silverstate55's Avatar
    Join Date
    Apr 2009
    Cedar City, UT
    MVPA
    35642
    Posts
    1,776
    Thanks
    10,883
    Default
    The only real issue you’ll have is fitting the 20-inch wheel over the front drums; the valve stem will interfere with the figment. You’ll either have to grind down the front drums or use a 22.5-inch wide flotation wheel with the valve stem mounted outboard.
  5. #4
    Private
    Join Date
    Nov 2019
    Fond du Lac, WI
    Posts
    Thanks
    Default
    What do you mean by, redo the power divider switch. Wouldn’t turning the front axle switch off work?
  6. #5
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,619
    Thanks
    108
    Default
    Quote Originally Posted by AMgeneral3945 View Post
    You want 2 switches. One to engage the front axle. And a seperate one to engage the front tandem axle rather than both being locked in when you flip the current dash switch.
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    MEP-804A
    Wes
  7. The Following User Says Thank You to simp5782 For This Useful Post:
    silverstate55 (11-14-2019)
  8. #6
    Private
    Join Date
    Nov 2019
    Fond du Lac, WI
    Posts
    Thanks
    Default
    Ok I see what you mean, but what is the benefit of doing that? Could there be potential failure with the drives or is it just having the option of the front axles locked without having to have both the front axle and front tandem axle locked at the same time.
  9. #7
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,619
    Thanks
    108
    Default
    You will have both rear axles with lockers pulling together on their own rather than just 1 axle on its own. Gives you more power offroad it would also allow you to unlock the front end but leave the rear locked in for making turns in a field and what not. Allows for more power to the ground for on road use if you are loaded when you have low traction without increasing turning radius or front driveline wear
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    MEP-804A
    Wes
  10. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
    silverstate55 (11-14-2019), Terracoma (11-15-2019)
  11. #8
    Private
    Join Date
    Nov 2019
    Fond du Lac, WI
    Posts
    Thanks
    Default
    That would be nice to have. Thanks for the help. Is it hard to wire in another switch?
  12. #9
    Join Date
    Jun 2011
    Memphis, TN
    Posts
    7,619
    Thanks
    108
    Default
    No. The switch you seek is napa/haldex 229635RX. You will remove obe of the delivery lines from the main switch and run it to it. You will have to add a supply air line from a fitting on the firewall or wherever you want to put the switch. You will simply install a plug in the port you removed the line and air fitting from on the original switch
    M923A1
    M931A2
    M1083
    M1078
    M796 Bolster
    MEP-804A
    Wes
  13. The Following 2 Users Say Thank You to simp5782 For This Useful Post:
    mac5005 (11-15-2019), silverstate55 (11-14-2019)
  14. #10
    Private
    Join Date
    Nov 2019
    Fond du Lac, WI
    Posts
    Thanks
    Default
    Ok, we’ll probably end up doing this. Seems like a nice option to have. Thanks for the idea and help
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
