Results 1 to 10 of 10
Thread: cvc helmet retrofit help
  1. #1
    Sergeant snakeater's Avatar
    Join Date
    Jan 2009
    jackson, tn.
    Posts
    94
    Thanks
    Default cvc helmet retrofit help
    has anyone ever been into one of the cvc tanker helmets electronics? i am wondering if they can be retrofitted to be used as an intercom in a deuce? I found a few of them for sale on ebay and here locally. i thought it would be cool to use them as hearing protection in my big deuce, but have them functional as an intercom and maybe vehicle to vehicle with another host radio. I am not interested in being military correct. I would like it to interface into something like the smaller motorola talkabout radios or something like that. Ideas? Observations? help me out here guys. Snakeater
    1970 M-35a2 w/winch (bobbed) ----sold
    1966 m-715 (modified)------sold
    1967 M-715 ( caterpillar engine)
    19?? M-62 5 ton wrecker
  2. #2
    Colonel TACTICAL6's Avatar
    Join Date
    Oct 2008
    Newark, Ohio
    Posts
    384
    Thanks
    31
    Default
    Actually I have a vic-1 intercom setup in my pinzgauer. And cvc helmets plug rite in, all you need is a bail out cord and all the rite cables and you are good to go.
    "The dead know only one thing: it is better to be alive. " -Private Joker
  3. #3
    Join Date
    Jan 2009
    jackson, tn.
    Posts
    94
    Thanks
    Default
    I am probably going to end up using a aviation intercom inside the truck, but wanted the option to go vehicle to vehicle if some of my buddies wanted to get the same setup. What provides power to the vic 1? Been too long for me and I can't remember. snakeater
  4. #4
    The Envelope Please. Steel Soldiers Vendor CARNAC's Avatar
    Join Date
    Jul 2007
    Corpus Christi, TX
    Posts
    8,148
    Thanks
    114
    Default
    Here ya go. A thread I did a long while back. It should provide you the info you're looking for.
    http://www.steelsoldiers.com/showthr...ighlight=vic-1
    No longer the Common Man
    'But I have dreamed a dreary dream, Beyond the Isle of Skye;
    I saw a dead man win a fight, And I think that man was I.'
    Hereby declaring open season on good idea fairies and there is no bag limit!
  5. #5
    Join Date
    Jul 2007
    Corpus Christi, TX
    Posts
    8,148
    Thanks
    114
    Default
    Oh and yes you can use a CVC or several other headset/microphone systems with the VIC-1.
  6. #6
    Join Date
    Jan 2009
    jackson, tn.
    Posts
    94
    Thanks
    Default
    has anyone tried to replace the ends of the cables on the cvc bailout cables for civilian style connectors? That would allow the use of an aviation intercom instead of the five pieces of equipment that it takes to make the vic1 operate. This is more of what I am looking for.
  7. #7
    3 Star General AN/ARC186's Avatar
    Join Date
    Nov 2008
    Graham,Washington
    Posts
    997
    Thanks
    243
    RPM
    Quote Originally Posted by snakeater View Post
    I've used the U-93A/U plug as a retrofit, quite a few civilian helicopter intercoms use them. the inline jack is a U-92A/U and adapter cables are readily available to convert from a U-93A/U plug to the two plug system(PJ-068 and PJ-055) found in most aircraft.
    here's a link to a page with the adapter cable. these guys also sell headsets and intercoms. http://www.sportys.com/acb/showdetl....=1350&CATID=94
    Hope that helps
    "To err is human....To arr is pirate!
    Dan
    1967 M35A2 "The Wee Beastie"
    Now gone to a good home.
    so on the lookout for a new project....
    Graham, WA.
  8. #8
    Join Date
    Jan 2009
    jackson, tn.
    Posts
    94
    Thanks
    Default
    that was what I needed thank you sir. Snakeater
  9. #9
    Corporal
    Join Date
    May 2019
    Wisconsin
    Posts
    31
    Thanks
    Default
    Do you have the information on using CVC Bose helmets for VIC-1 units? I'm trying to get my unit up and running.
    Kevin Nelezen
    M936A2 Wrecker
    M35A3 Deuce
    M105A2 Trailer
    MEP-016C
  10. #10
    Moderator MWMULES's Avatar
    Join Date
    Sep 2007
    DESOTO, KANSAS
    MVPA
    10023
    Posts
    5,408
    Thanks
    1,431
    Default
    The Bose wiring in the cord/ plug is the same as the older CVC's
    HMIC of BEEFCO Industries world wide.
Similar Threads
  1. Replies: 12
    Last Post: 11-13-2004, 05:18
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
