Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: M Series Door Latch Repair
  1. #11
    Sergeant
    Join Date
    Jan 2012
    Fawn Twp. PA
    Posts
    81
    463
    Default
    Quote Originally Posted by BigSky View Post
    Can Someone help me with how to get the latch mechanism out of the door? I need to replace the spring. It broke off in two parts. One part is still in the mechanism, the other I did find inside the door frame after removing the side panel.
    I don't remember it being difficult, so I just took a look.
    It looks like you remove the door handle (1 screw in the center), and the 3 screws surrounding it, and then remove the 3 screws around the latch. 1 on the interior, and 2 on the back edge of the door, above and below the actual latch. Then drop the whole thing down and out the access panel.
    Depending on how yours is broken into 2 pieces, the fishing it out the access panel may be even easier than usual.
    AJ
    Tarentum, PA
    1966 Kaiser Jeep M35A2 whistler w/w
  2. The Following User Says Thank You to Yarz For This Useful Post:
    M-37Bruce (07-13-2019)
  3. #12
    2 Star General M-37Bruce's Avatar
    Join Date
    Nov 2007
    Midlothian, VA
    Posts
    642
    668
    Default
    I'll look into it, I might even have some pictures somewhere?
    Bruce
    1953 Dodge M-37, aka Da' OD Goddess
    Issued to the Dept. Of The Navy
    January 1953
    VMVA
    Stanford Hill Farm
    Midlothian,VA
Similar Threads
  1. 5 Ton
    By mangus580 in forum WIKI
    Last Post: 04-16-2018, 18:17
  2. Help-vinyl cover repair
    By 196thprober in forum Website Help
    Last Post: 04-30-2009, 20:25
  3. M39 vs 800 series
    By davesgmc in forum 5-ton and up
    Last Post: 04-09-2009, 16:32
  4. How long have you owned M809 series trucks?
    By BKubu in forum 5-ton and up
    Last Post: 01-25-2009, 16:16
  5. Replies: 20
    Last Post: 08-09-2008, 14:34
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
