Chuggin84'
- 0
- 0
- Scott AFB, IL
Need HELP! Trying to use a Haynes manual to diagnose a glow pug problem. I know diesel's are hard to start in cold weather, but mine wouldn't even start when it's 35* out. I spent two weeks having my buddies jump me, or push my truck to a stall at the fire station I work at; just to warm my truck up enough to start it. I pulled the glow-plugs and replaced them. I had a buddy come over with a voltmeter and found that I was only getting less than 6V at this GP temp switch/ inhibit switch located on the left rear of my engine. The wire harness lead was carroded and basically fell apart when I was inspecting it. I tried researching the part at O'Reiley's and it kept pulling up a 6 pin configuration. I have a two wire setup. The male end of the plug has a metal band on the outside and a center female metal connector. Does anyone know a part number I can reference from anywhere!! I'll try and attach a pic.
