RenegadeActual
13
Az
Previous 2 owners did near 0 maintenance on the cooling system of my M54A2. I replaced the waterpump, had the radiator rodded, replaced every hose, replaced the thermostat, replaced the headgaskets, had the heads resurfaces 7 thousandths, changed the oil, filled with new sca global coolant, replaced the in tank fuel pump, replaced the fuel filters, rewired the fuel pump circuit. And now Im chasing down and repairing all the air leaks.
Sent from my SM-S918U using Tapatalk
Wreckclues
437
Jefferson, Massachusetts
My rig came with a 3/4 inch draincock installed in the air intake pipe. I'm assuming it was a modification for squirting starter fluid directly into the air supply as it made no sense as a drain being mounted on the upper part of the air pipe. If there was that much "condensation" in my pipe I'd be in deep cah, cah.
It was difficult to secure and would pop out if brushed against. Replaced it with a 3/4 inch bait tank plug. It's easy to remove for starting while being flush with the pipe when secured.
19,144
Like @US6x4 suggested, be careful with the little "giblets" of rubber inside the intake tube. Might even be worth removing the elbow and dumping it out. Yeah, it isn't metal but it sure won't help make your engine run any better or faster if it ingests a bunch of rubber shavings.
The bait plug though is a great idea!
G744
3,487
Hidden Valley, Az
I fired up the old girl in a hurry and got her out of the path of this brushfire we had last Friday. It came right up to our fenceline, luckily I had enough time to get some water on that area so it didn't cross.
All told, it burned almost a hundred acres of nearby desert, but no structures were damaged.
19,144
View attachment 921328View attachment 921329
Darn lucky that it didn't cross your fence!
What did you do to pump enough water to stop it there?
Happy to hear that you and your truck survived the mess.
hgun
311
Leechburg, PA
Hi guys I got a question will the PTO off of a M51 work on a M817? Wasn’t sure if the Multi fuel 5 tons transmission was the same as a 800 series. A friend of mines 817 the PTO broke off the transmission but he has a M51 and was curious if he could swap. I told him I would ask you guys. Thank you
Joe Bertram
238
33
Indiana
Mine all look the same with exception of my 800 series are single outputs
hgun
311
Leechburg, PA
Hi guys I’m finishing up the 818. I seem to have a possible light issue. No turn signals or headlights. Now I do not have the rear lights connected is that why kinda like an open? My front markers light but don’t blink. Black out lights on markers work. But no headlights at all now I haven’t dug into checking for voltage at the headlights. I’m hoping once I get my rear lights connected maybe they will work. I have a NOS rear harness installed. Just curious if their is something else to check thank you.
Joe Bertram
238
33
Indiana
Check your grounds especially at the headlights. I chased mine down to bad ground at the headlight harness to front fender
hgun
311
Leechburg, PA
I got the head lights working lol it was the loose nut between the steering wheel and seat. No turn signals yet they get brighter when turned on but no blink. I checked voltage going to the blinker flash module im getting voltage to it. I ordered a new one. Installed the rear lights, and got the heater wired up and it moves air don’t know about heat yet it gets smoky in the garage when I start it in there. Few more items to put on them I’ll take more pics and post it in the classifieds. So hopefully it will sell so I can pursue my M931A1.
