RenegadeActual
39
13
Az
Previous 2 owners did near 0 maintenance on the cooling system of my M54A2. I replaced the waterpump, had the radiator rodded, replaced every hose, replaced the thermostat, replaced the headgaskets, had the heads resurfaces 7 thousandths, changed the oil, filled with new sca global coolant, replaced the in tank fuel pump, replaced the fuel filters, rewired the fuel pump circuit. And now Im chasing down and repairing all the air leaks.
Sent from my SM-S918U using Tapatalk
Wreckclues
434
Jefferson, Massachusetts
My rig came with a 3/4 inch draincock installed in the air intake pipe. I'm assuming it was a modification for squirting starter fluid directly into the air supply as it made no sense as a drain being mounted on the upper part of the air pipe. If there was that much "condensation" in my pipe I'd be in deep cah, cah.
It was difficult to secure and would pop out if brushed against. Replaced it with a 3/4 inch bait tank plug. It's easy to remove for starting while being flush with the pipe when secured.
19,089
Like @US6x4 suggested, be careful with the little "giblets" of rubber inside the intake tube. Might even be worth removing the elbow and dumping it out. Yeah, it isn't metal but it sure won't help make your engine run any better or faster if it ingests a bunch of rubber shavings.
The bait plug though is a great idea!
G744
3,478
Hidden Valley, Az
I fired up the old girl in a hurry and got her out of the path of this brushfire we had last Friday. It came right up to our fenceline, luckily I had enough time to get some water on that area so it didn't cross.
All told, it burned almost a hundred acres of nearby desert, but no structures were damaged.
19,089
View attachment 921328View attachment 921329
Darn lucky that it didn't cross your fence!
What did you do to pump enough water to stop it there?
Happy to hear that you and your truck survived the mess.
hgun
309
Leechburg, PA
Hi guys I got a question will the PTO off of a M51 work on a M817? Wasn’t sure if the Multi fuel 5 tons transmission was the same as a 800 series. A friend of mines 817 the PTO broke off the transmission but he has a M51 and was curious if he could swap. I told him I would ask you guys. Thank you
Joe Bertram
221
33
Indiana
Mine all look the same with exception of my 800 series are single outputs
