- 190
- 63
- 28
- Austin, TX
One of the reasons I'm looking for a M939 is to haul road-base gravel where there is no road. Assuming I get a M939 and I convert the bed to a dump bed, I'm also thinking about buying a civilian pup dump trailer and using the pintle to pull it. These are fairly common and cheap in my area but want to make sure the civilian dump trailers (or any civilian trailer) with air brakes hooks up to the M939 without issue. Is the military truck and civilian trailer air brake systems compatible? Any modifications I need to do? Maybe this is an obvious issue but I'm still learning. And I'm assuming electrical will be a separate issue but I understand there are adapters for that.
