- 2,155
- 63
- 48
- Zimmerman MN
I'm very confused on the snatch block I would need to pull my M936A2 out here. I'm confused if I could use the front winch or need to use the rear winch to pull itself out. In general I'm confused. I was planning on using an M923(once the ice melts allowing me to move it) as the fixed vehicle sitting on the road to attach the snatch block to, or in front of the wrecker if the front winch could be used in this scenario. What rating does the snatch block need to extract a 40,000lb vehicle? I have two 20,000 lb snatch blocks, but somehow I'm thinking that wouldn't be safe.
