Keyed battery cut off for m35 deuce
Those Military Guys
Rancho Cucamonga, CA
This kit is for deuce trucks with the batteries under the passenger door the cables have been designed to fit the DEUCE so you can mount the switch close to the driver for easy reach for the driver.
M35 Model Military Trucks!
Now you can have peace-of-mind when you leave your truck unattended. With this cutoff switch and a pair of our LOCKING DOOR HANDLES, your military truck will be just about as secure as you could hope for. The keyed switch is rated at 180 continuous amps and will handle a 1000 amp surge. The cables are heavy duty 2/0 welding cable.
Installation is straightforward, and is easily accomplished with simple hand tools and easy-to-follow instructions. Any questions please call and we will be happy to help! 909-703-1400
$79.00
https://thosemilitaryguys.com/collections/deuce-parts/products/keyed-battery-cutoff-for-the-deuce
For added security look up our keyed Ignition Switches for Military Trucks!
