cucvrus
- 9,763
- 113
- Jonestown Pennsylvania
The more I look the more I find. I removed the radiator today. I am optimistic about this radiator. It appears it has been replaced. The aluminum oil cooler lines have both been replaced. The bracket is missing that holds the cooler line in place on the fan shroud so someone opted to use wire ties. Easy to drain the coolant on this unit. No inner skirts to deal with. Nice threaded bolt that was threaded into nothing. It got tight in the shroud. Aluminum cooler lines have been replaced with Genuine GM. That in itself is a plus. The isolator support pads were not doing anything anymore. The hoses were oil soaked and seized to the engine. Like usual. All in all the core support on the M1009 is still descent. The radiator has hope also. it appears it was leaking near the top hose mount. I will send it out to the radiator shop tomorrow and get it checked out. The best price I found on replacement plastic aluminum radiators is $310. I would rather be able to have this one gone over for 1/2 that price. After some cleaning and coating I want to get into the reassembly process. Have a Great Day. It was a decent day threatening rain the whole time I was working outside in the driveway. I like working outside when ever possible. It is so much easier to see and makes the job go much quicker. I found a 1/2 dozen other issues. I need to work blind folded.
