Engine oil pan leak M35A2
AIE1
Arlington, Virginia
Question: is it possible to pull the engine oil pan without completely pulling the engine? Was thinking of removing front mounts, jack shaft, transmission cover. Your thoughts? Thanks
AIE1
Arlington, Virginia
Thanks , thats what I didn’t want to hear. **** firewall is to close to rear lift ring. And no sir I wasn’t messing with you. Be a one man show when removing a Duce engine ain’t no fun.
cattlerepairman
3,149
NORTH (Canada)
Lifting the front end on the frame and letting the axle hang might give you enough clearance to get the pan out. Safe working practices recommended.
Sent from my SM-G950W using Tapatalk
davidb56
1,237
Bonners Ferry Idaho
BTW...its in the technical manual section on the website if you do not have the manuals. Also, If you use the search section and type in "oil pan gasket replacement", you'll have to sort through a couple hundred threads before finding one or two that actually pertain to the oil pan. Not good if your using a I phone.
SETOYOTA
421
georgia
I replaced a pan and did not move the motor. The last deuce I bought from GL had a forklift hole in the pan.
