Gooseneck trailer hitch on M923
sandcobra164
321
Leesburg, GA
I think I have seen a thread on this before but search is not my friend tonight. I have come across a pretty decent deal on a camper that needs to be pulled home with a truck compatible with a gooseneck adapter in the bed. I would like to equip my cargo truck to be able to pull it while retaining the bed and cargo cover. I think that I saw a thread that detailed a set-up coming off of the rear frame rails that was low enough to tow a camper level but I can't find it. Has anyone done this that can provide some details?
Thanks Kindly,
Joseph
simp5782
Feo, Fuerte y Formal
9,492
Mason, TN
https://www.steelsoldiers.com/showthread.php?t=54202
You can also do a drop receiver style hitch with a trussed up setup to extend well out past the rear of the truck. As long as it is reinforced it should be fine.
Or buy a scrapped out rear truck frame and turn it into a dolly.
Sent from my SM-G935P using Tapatalk
sandcobra164
321
Leesburg, GA
I really like the setup shown in the linked thread. It might require some help from an engineer who is also a fabricator to modify the camper. Luckily I'm friends with a man who is both. Dolly's are nice but I would like to be able to back the combination up and having two pivot points might exceed my driving ability.
simp5782
9,492
Mason, TN
I single axle dolly is easy to back up. now a double axle dolly like what I have is a full blown mfr. Cause the one axle tries to push thru the other side on turns. OR if you have trouble backing just add the pintle to the front of the truck and push it into place.
Jericho
70
Landaff NH
IMG_0105.jpgIMG_0103.jpgIMG_0104.jpgCheck out a couple of threads on 931 and fifth wheel RV towing, I routinely haul a 36 foot bumper hanger on my 931, I added a hitch , also use it for a fifthwhell (did take advice from here and added a shock absorbing modification to the fifth wheel, rugged and simple , watch your length to ensure it clears your trailer /fifth wheel
Jericho
70
Landaff NH
I junctioned the lights wiring to the travel trailer with mil spec one to two connectors from Eriks (changed bulbs to 24 volt ) (hope to go to LED when I get time ) and added a 7 pin receptical, then ran my electric brake wire thru a 24/12 30 amp unit to run the charge circuit and electric brake, (got idea here from the guys ) Probably took a couple of hours to peck away at it , easy mod
