TM's for the 939 series trucks
Admin
3,170
n/a
Listed below are a number of the TM's for the 939 series trucks. To save them to your computer, right click, select "save as"
LO9-2320-272-12.pdf
LO9-2320-272-12 Lubrication order for the M939 series trucks. June 1990
TM9-2320-272-10.pdf
TM9-2320-272-10 Operations manual for the M939 series trucks. Sept 2004
TM9-2320-272-24-1.pdf
TM9-2320-272-24-1 Unit, Direct and General support manual for the M939 series truck. 1 of 4. Oct. 1992
TM9-2320-272-24-2.pdf
TM9-2320-272-24-2 Unit, Direct and General support manual for the M939 series truck. 2 of 4. Oct. 1992
TM9-2320-272-24-3.pdf
TM9-2320-272-24-3 Unit, Direct and General support manual for the M939 series truck. 3 of 4. Oct. 1992
TM9-2320-272-24-4.pdf
TM9-2320-272-24-4 Unit, Direct and General support manual for the M939 series truck. 4 of 4. Oct 1992
TM9-2320-272-24P-1.pdf
TM9-2320-272-24P-1 Unit, Direct and General support parts and special tools manual for the M939 series truck. 1 of 2. Feb 1999
TM9-2320-272-24P-2.pdf
TM9-2320-272-24P-2 Unit, Direct and General support parts and special tools manual for the M939 series truck. 2 of 2. Feb 1999
AMG_ABS_MWO_field_service.pdf
AMG_ABS_MWO_field_service ABS MWO field service guide.
M939_tires.pdf
M939_tires Document about 14.00 size tire replacement on the 939 series.
extract_TB43-0001-62-03-1.pdf
extract_TB43-0001-62-03-1 Extract for TB 43-0001-62-03-1 for the 939 series.
M939_ABS_maint_sustainment_tng_std_handout.pdf
M939_ABS_maint_sustainment_tng_std_handout additional handout for the ABS of the M939 series.
M939_P2P.zip
M939 Series Interactive Systems Guide - Download .zip file, right-click the .zip file and select unzip contents, put the M939 P2P file in your Program Files directory, open the M939 P2P folder, right-click on the runa6w32.exe file, select Send To, select Desktop (create shortcut), go to desktop, right-click on the new shortcut, select properties, select the shortcut tab, make sure the target box shows "C:\Program Files\M939 P2P\runa6w32.exe" c:\Program Files\M939 P2P\nav.a6r, make sure the start in box is empty. This should allow you to double-click the shortcut on your desktop and start the P2P program.
