1028 rear shocks
319cssb
221
Easley SC
On my 1028 i have rear shocks with some coil over design. Is there a replacement for the shocks around? It looks like the springs come apart and can be mounted on a same diameter shock
cucvrus
10,501
Jonestown Pennsylvania
If your M1028 needs coil spring shocks you have bigger problems. That truck can handle a lot of weight on the stock leaf springs. Coil spring shocks won't do diddly after the leaf springs are loaded up. I broke a few stock springs mounts off the axle on my M1028 when I was rebuilding my house. I used it to haul everything from dirt, bricks, and stone. Many miles of use. But the shock mounts on the axle were the weak link. If it were mine I would just put on stock Monroe gasmatics and call it a day.
nyoffroad
737
Rochester NY
I think that is called "coil over" and was a common way to increase load capacity or fide height. I've seen them available but $$$, you have the springs just replace the shocks.
rtk
449
Lockport N.Y.
Yup , follow the above advice . I just installed a set of standard Delco gas shocks all around on my 1031 , also while you are checking shocks don't forgot the steering damper , most are like tire pumps after 35 years .
rtk
449
Lockport N.Y.
Those are old school coil over shocks , pretty useless on a 1028 . Just use a good set of hd shocks .
Matt5
Banned
214
Junk, you are going to try to put a load on those little shock mounts? Get a set of KYB monomax's and hope they aint junk like everything else...
ehuppert
142
Upstate NY
That style shock is junk and are generally used to supplement springs that are sagging or weak. As stated, the shock mounts aren't meant to support any large amount of weight. First thing i normally tell a customer if i see those shocks is they need springs...
Just put KYB mono max on my 1008. Still finishing the long restoration, so no idea how they rate!
cucvrus
10,501
Hey let's see some pictures of that restoration. Breathing life bak into a frame and cab that has been dead since 2005 is a chore in itself. Very interested to see it here in Pennsylvania.
