1028 with M35 cargo bed?
BOSN
NH
I found a pic of what looks to be a 1028 with a cargo bed from a M35 on it, anyone have experience with this swap? I figured whoever did this might be a member on here.
Im looking to something similar to my 89 V3500 cab and chassis (159.5" wb)
bachman502
58
Chesapeake, VA
If your going to try something like that, use a LMTV bed. They have aluminum drop sides. The deuce beds rot around the stake pockets and the front. Not the best designed beds in my opinion. You will have a hard time finding a deuce bed in decent shape.
BOSN
NH
I thought about the M105 trailer bed, but it's not long enough for my wheel base. from the back of my frame to the cab is roughly 10'8", so I'd have to cut the frame and driveshaft or extend the bed.
There aren't drains in the base of the stake pockets on the M35 beds? Not Cool.
1,823
Its a great idea. I have an 87 V30 with 159.5" wb as well. The deuce bed weighs nearly a ton so it might limit your GVWR. They look tough as nails though.
BOSN
NH
Did you cut down the length or leave it at 12'?
How did the bed line up with the truck frame rails? From what I have read bed frame rails are 34", same as the 1 ton frame.
Is it set up with a dump?
Are you sure about the weight? 2000lbs sounds like a lot. I was figuring 750-1000 lbs.
Got any pics?????
Sorry for all the questions, just glad to hear someone else has done this before!
BOSN
NH
Those drop sides must make a **** of a racket though. 2 hinged sides and a tailgate all vibrating and clanging around.
I haven't been able to find any weight estimates on the 12' cargo bed (M35) I was just guessing 1000 lbs or less. anyone know for sure?
502NDMP
NH
I just sold a drop side bed, I love them and the noise wasn't ever an issue.
502NDMP
NH
The weight is around a ton, they are heavy. We used a 5 ton crane to remove the last one.
