1100-20's on deuce rims as duals
Adamlee
Alexandria, VA
Can someone send in a pic of a "stock" deuce with 1100-20's on stock rims.....as duals?
Someone seemed to have said there actually was a bit of a gap between the rear tires done this way....
If so, I'm thinking about running 10 of the 1100-20's since I've found a good source.
Plus, the truck will be a little taller....
Loose Deuce
South MS.
mcinfantry, Is that one of those NAPA Mufflers on your truck ? If yes how do you like it ?
You mentioned on your site about a search light, you see any of those 100 amp lights that they had on the M60 tanks ? hee,hee
jwaller
20
Columbia, SC
what kinda extra height do you get from the 11x20's.
1, 2 or 3 inches?
with the same rpm's what kinda extra speed on the highway will this give us?
