120 psi gauge connections
Tinwoodsman
77
Comfort, Texas
I replaced my 60 psi oil pressure gauge with a 120 psi. I must confused as to the wire connections. Does the #27 wire (from the spider harness) go to the ribbed connector of the smooth connector?
1,193
I can't remember right now but, if you look at the rest of the power wires from the spider harness behind the gauge panel, they should all be going to the same side/connector of each gauge (ribbed or not ribbed), then you will know which side gets power and which side gets the sender unit.
Tinwoodsman
77
Comfort, Texas
The problem I have is that they were flip flopped between the 60 and 120 gauges. At least that is what I remember. I check under the dash again.
Thanks,
1,193
I didnt mean the physical side of the gauge, I meant the side with or without the ribs.
1,163
Most of our gauges actually say "IGN" on the side of the gauge for the #27 circuit
Tinwoodsman
77
Comfort, Texas
Doghead, I did what you suggested and made a note of the spider harness connections to each gauge. I tried this with my 120 psi gauge and it did not work. I reversed the connections for the 27 wire (spider) and the 36 wire from the sender. Voila, it worked and I do indeed have oil pressure. I remember noting that this was opposite from the 60 psi gauge I removed. Go figure!!! :roll:
1,193
Interesting, I hope I can remember that the next time it comes up! Thanks
Sorry my idea was not correct or helpful.
Tinwoodsman
77
Comfort, Texas
Cranetruck, while it may appear to be an error, my 120 psi gauge (purchased from White Owl Trucks) connects just like the PM in order to function. Not sure why but that is how it is. Maybe the manufacturer read the PM :-D
