LuckeyD
- 376
- 63
- Vilseck, Germany
Good day: 15KW TQG info all I needed for 20 years. Was designed for small 3 phase uses. Requires a bit of work to work on todays high electrical use homes that are 120/240VAC instead of changing to a 3 phase house entrance because of heat pumps and electrical heating.
Issues: faulty fuel, so use clean DF2. Fan belt stretches. causes squealing. Oil filter mounting, injector pump and solenoid issues, K1, Mag Pickup and A5 issues. Voltage regulator issues. Load terminal issues. Once in order, this gen will serve you well. Service it.
